Yamaha 6 HP part is for
garygpd
hi - wondering if anyone know what this circled part on Yamaha 6 hp 2 stoke is for and function ? thanks
It is supposed to lock the recoil starter when motor is in gear.----Only allows you to pull recoil with motor in neutral.
garygpd
Thank you tons for your great knowledge , have great 1
hi do you know what this red circled part is for on 1995 40 hp mariner pro series tracker is for , thanks lots
garygpd
hi do you know what this red circled part is for on 1995 40 hp mariner tracker pro series , thanks
garygpd
Cosmetic.----It has to look good and " fast " I think.
hi thanks for great info you are very helpfully + smart , i,ve been wondering use of cover for long time as seems does not do much + when removed , is very little exposed on motor - cover has small internal spring - i guess mostly to keep tension on mounting bolt/s
