BadBear603
- Joined
- Mar 20, 2011
- 7
I have a 1988 Merc 90hp, 3 cyl, 2 stroke. It has oil injection. I have a 22 gal Moeller tank under the bench seat. I was having problems with the motor and noticed the fuel pump was leaking pretty badly. I ordered a new fuel pump. It was an aftermarket one that was pretty useless but I used the gaskets & diaphragms to rebuild the existing pump. I ran the motor but still had problems bogging down under load. I found a lot of water at the bottom of the fuel tank. While installing a fuel/water separator I had to cut the old fuel line. I noticed oil in the gas all the way from the motor back to the tank. (None in the tank, pure gas). Is this normal? For oil to “backflow” from the motor? I don’t recall any oil in the few drips of gas when I disconnected fuel lines in the past. Thanks.
