1984 mercury bleed lines
That old Mercury
Hello Everyone
I bought an old bass boat with a Mercury 150 2 stroke v6 and old age and rats have chewed up the bleed lines and i dont know where to hook them up correctly.
My engine has 5 hoses total on the cylinders . 1 to the airbox
My motor also has vertical reeds.
I have read a ton of articles on the internet and i just cant find any good drawings.
I want to get it running before i buy a manual to make sure its worth a few bucks.
All help will be Greatly appreciated!
Dukedog
copy and paste this address..... ya gotta rotate it!
file:///C:/Users/allys/Downloads/Old%20Downloads/vert.%20bleed%20lines.pdf
That old Mercury
Thank you
When i click on the link it says i need to be logged in
Hi
I can see the pictures and post a reply so i dont know why it says i need to be logged in to click on the pictures? Looking at the pictures they dont match what was on my motor .
That old Mercury
Buy the manual
Hi
Do you know what manual i need for a 1984 mercury that will show the bleed line routing clearly ?
I read about a whole lot of people buying manuals and what they are looking for are not shown.
I have ran lines where i think they go by reading a lot.
With it sitting 20+ years i just plan to crank it up and see how it runs, if it knocks or acts like it needs a lot of money spent on it then i wont be wasted money on a manual and just repower it.
Compression is on average 120 psi .
Thanks
Dukedog
think tha one in my link is 90-97658.. its in tha link if ya can get it opened on a lap top by copy n paste tha address........
you can jus block 'em off and it will run.. won't hurt a thing.. it will jus load up at idle but should clear up with throttle added........... make sure tha motor is level or a bit positive trim...
That old Mercury
Hi
Dont plug the bleed holes if you plan to rev it up, they will blow off if not secured properly !
It will blow oil and gas on you like it does out of the carb with a broken reed valve!
Well after 7 hours of soldering replaced chewed up wires it Runs after sitting 20 or so years.
It doesnt idle the best and has a slight missfire on cyl #1 and #5 but after all that time sitting I am happy with it and I am willing to spend i few bucks on it.
It does not appear to have any labyrinth crank shaft seal leaks that i have repaired before but its too soon tell.
Thanks again for the help and i will probably have some more questions on Mercury motors in the future.
That old Mercury
That motor does not have labyrinth seals
Hi
I was using the engineering term for that kind of ring, not the book or part ordering name of a crankshaft compression ring.
I have never torn down a mercury but it still has to seal off each combustion cylinder seperately like any other multi cylinder two stroke engine.
I have seen a few older two stroke motor cycle engines that didnt though.
Are you saying the older mercurys dont?
Or was it just my term ?
I might have to look into this more if it does not have individual cylinder sealing.
Sorry my message was so long i just want to be clear on what i am dealing with.
Thank ya'll for all the help!
merc850
You can see the labyrinth ridges in this picture of an inline enginereed-stops.jpgand this picture shows the sealing rings of a V6V6Powerheads0077.jpg
That old Mercury
Hi
I need to correct something.
You were completely Right they can be blocked off with no problem.
I ran my motor in a tub this morning by doing this when i accelerated it i heard a cough and it blew the rubber hose off of #2
I put it back on gas it gas #1 blew off then again and #5 blew off. I put on some clear hose on #1 and when i cranked it #1 blew a hole in the hose right at the nipple and smoke came out.
The timing was off about 10 turns on the screw.
No more cough so i plugged them and it ran fine and did not blow any off.
I also learned something i did not ever think about and did not know since i have always ran rubber the black rubber hose not the clear hose.
The nipples on the cylinder are pulling the vaccumn . Not the intake nipples !
Thats pretty cool Thanks for plug them comment, i never would have figured this out when i got it on the water
Thank you
That old Mercury
You can see the labyrinth ridges in this picture of an inline engineView attachment 391305and this picture shows the sealing rings of a V6View attachment 391306
Thanks
Just like johnson, evinrude.
I was not sure what Mercury used .
I thought it would be the same but was not sure.
I do need to check the reeds but i need gaskets and have not found one yet that was for verticle reeds on the normal purchase sites. I did not want to mention them since i dont want to advertise sites.
Thanks a lot
