73 Dolphin
Thread starter- Joined
- Oct 8, 2008
- 309
I put my boat on the water after sitting for probably 20 years.
Ran like a beast but carbs leaked when I ran it so I rebuilt and ran them in a barrel, and all was good. I had already rebuilt the water pump and it seemed to be pumping well but I watched a YouTube video and it pointed out that I hadn't used liquid gasket and triple grease so I went and ordered an all new OEM water pump, liquid gasket, triple grease and the Evinrude 847 or whatever its called. Pulling the lower unit it didn't want to drop. I think maybe the pin was still grabbing on the gear shift. Eventually it dropped and I replaced the new generic water pump with the Johnson OEM kit. All the gasket sealants grease and such. I noticed that the gear shift rod wouldn't shift at all with the lower unit off. Completely locked up. It was great. I had just ran and shifted the day before I decided to do the full OEM treatment.
The question is this. Should you be able to just pull on the shift lever to change between F/N/R or does it need the leverage from being connected and the controls??
I'm really concerned that I just trashed my lower by changing the water pump.
