Alarm Sounds when batteries switched on and no key in ignition
Found the issue
Had checks done by electrician and found the Rule float switch was the issue
Replaced and all good
Glad you found it but Dang, would sure like to know how it was wired to cause the problem
cabrio777
Thanks to all the suggestions
Had to trace the siren wires back pretty much undo clamps on massiveblock wires behind the dash. Was looped into the fuse panel with an extra fuse inline. Then trace wires back to the rear of boat.
Which was connected to float switch
Cut wires there siren stopped
Bilge float switch replaced and worked perfect.
was just coincidence that i had all work done on motor the same time the switch decided to give up
Lucky I had a great elect troubleshooter stay for a few days and sorted the issue
  • 20231106_175254.mp4
Grub54891
Glad you got it sorted out. A bit different than most, us those float switches don’t work, seldom get stuck on. Unless it was the beeper itself, I’ve seen them short and keep running.
