yep , pictures
standard pontoon construction has "M" brackets welded to the top of the toons and these brackets, at least on mine, are bolted to the "L" shaped stringers running width wise.
Its all aluminum, so It's possible you tweaked the alignment, and could've possibly cracked the weld between the toon and a bracket, which could/would let water in. You said hard so I wouldn't rule out cracking the weld between the toon sections.....
pictures....
