2007 mercruiser 5.0 alpha TKS system
Welcome
It's open when cold
After motor warms up it closes to keep voltage on the TKS module to keep it from adding more fuel
Searaytally
Welcome
It's open when cold
I am having issues with TKS system. The motor will not run with both the diode and temp sensor connected. if I have on or the other disconnected the motor will run at high idle. The sensor does not close at operating temp. If I have the motor running with the diode disconnected. I gave 13.5 volts on both side of the diode. If I plug I the diode the motor dies. Any thoughts?
What purpose does the diode serve?
Diodes flow current in only one direction. So key ON current starts flowing to TKS module.
Motor warms up and temp switch closes also sending current to switch.
Key off temp switch current continues and diode keeps it from Flowing back to motor. If diode shorts then motor can't be shut off
