1975oday22
Thread starter- Joined
- Sep 2, 2022
- 601
Looks like Leonard had it together that day lol Motor is looking like new! Doesn't look like it needs a damn thing but to be run.some new shots of the 92 mariner 6hp engine to tie you all over till i get the wiring and lighting.... super clean this is. ..... should purr like a kitten ......
it does look new. i never touched it except to open it up and take picks...Looks like Leonard had it together that day lol Motor is looking like new! Doesn't look like it needs a damn thing but to be run.
I like the way that looks in there with the rounded opening framing it all up and making the panel nicely recessed to protect your switches! Seems like that's the best spot and to have tour battery near there would be really convenient and probably best for weight distribution too. Right under the door seem like a great spot bc it is otherwise a kinda unused area but it is also probably the wettest area, especially stepping into cabin in rain etc. so thinking the other spot would be better just for that reason alone.laying out my new switch panel. it might change , still waiting to hear back from someone about a switch panel im looking at. but here is what my thoughts are so far. just the switches layout.
So they filled those areas with little foam scraps? I was expecting the spray in stuff. Well that'll be way easier to remove!this is not my boat, however this is what i have to look forward to when i get the paint outta the screw heads. i will then proceed to take them all out. maybe keep some but not likely. and make storage under there instead.
Looking good! I see you got yourself a nice big group 24 battery to play with. Not sure if switches like that are still available, or not.. Shoreline marine has similar looking black toggles but not exactly the same. Is there a brand name visible? I only see an F.here is a few shots of what i have done so far. i still have to try to countersink the screw on for the switches or i might just epoxy them in place. i need 5 more of these style. hopefully i can still get them? and still have to drill the hole for battery cutoff .
no brand name on them . so i think 10 new ones are gonna be in order. but first getting the wiring. then the end of january getting the switches , lights, ect...... i should be on the water for late may early june. hopefully if all goes well.Looking good! I see you got yourself a nice big group 24 battery to play with. Not sure if switches like that are still available, or not.. Shoreline marine has similar looking black toggles but not exactly the same. Is there a brand name visible? I only see an F.
Solid plan man, I'm basically doing the same approach with a number of things on mine. The wiring is the more important (and time consuming) work, swapping in newer switches later should be easy. Looking forward to seeing this baby in the water!no brand name on them . so i think 10 new ones are gonna be in order. but first getting the wiring. then the end of january getting the switches , lights, ect...... i should be on the water for late may early june. hopefully if all goes well.
