The creaking sound in the video is the trailer torsion axles not the steeringSteering!
Thats a good start although the steering must be weird with L/R reversed....Got the boat on the water yesterday, the motor stayed on and she might sit slightly lower in the rear than it used to but seems ok. I got very little propulsion though at different trim levels and RPM. Talked to a local propeller shop and they said that the 15 pitch should be good but it may not have enough cup in the blades. Dropping the prop off to them today.
Also found that the steering was reverseddidn't think about that. The rigging was different on the old OMC vs the outboard. Will need to run the cable through the other side of the box.
All in all I'm happy so far, got a few bugs to work out but that's why we test lol. Plus it was a beautiful day on the lake in northern Illinois for mid November.
Yes the steering was very confusing to say the least lolThats a good start although the steering must be weird with L/R reversed....
When you say you had very little propulsion - what do you mean? Did rpms climb with no forward momentum /prop splipping?
Or did rpms not go up?
Would also check the motor height if too low can cause too much drag. On my brothers Twin Vee power cat we had to raise the engine about 2" to get the cav plate where it should be underway
It's funny, the original prop was chewed up so I picked up the same 15.25x15 used but clean Honda OEM prop off eBay. I checked it this morning and someone had clearly stamped the prop and the hub. The marks were aligned but I'm thinking why would someone do that if they were not checking for hub spin? The original OEM prop has no stampings and it's clear that someone used a punch or something similar to mark the one from eBay. It does really seem to act like the hub is spun. The person at the prop shop did say that a prop without enough cup can have similar symptoms as a spun hub as well. I'll let them check it out.flip the helm on the steering
check the hub on the prop
Would think based on what rpm you give , if prop guy can repitch down 2” you should be there at wot rpm and improve holeshot. Adding cup drops wot rpm similar to adding pitch …Tried out the prop after cupping was added. Huge difference, was able to get up to and stay at 20 mph. Hole shot is poor yet, had to slowly bring up the RPM's to get it to 20. At wide open throttle it was at 5500 rpm, redline is 6000 so there is some room to play with. Prop guy said to let him know the results and he can make additional adjustments.
When I installed the shift and throttle cables I ran the ends all the way down so there may be some more throttle because the cable is at its shortest length? Also need to adjust the shift cable, shifting into gear is not as smooth as it could be.
That's all the testing for this year, cover is going on, will be finishing up interior seating over old engine bay etc before next season. All in all pretty successful I would say, a little over a month from a 1975 OMC I/O to a 2017 Honda outboard. Cutting and welding aluminum is as far as I want to go in boat work, God bless you guys laying down fiberglass!![]()
Thanks I'll be going back to him for more adjustment.Would think based on what rpm you give , if prop guy can repitch down 2” you should be there at wot rpm and improve holeshot. Adding cup drops wot rpm similar to adding pitch …
Thanks, prop place was closed today, I'll talk to them tomorrow.FWIW, my buds boat does 18mph with a 30hp.
I would think with the correct height and correct prop you should be closer to 30
