nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,096
Pulled the drive the other day. Had been dealing with a sticky shift shaft cable that had been worsening throughout the summer. Pulled the drive mid-summer and the cable seemed ok, so I pulled the inner, wiped/dry lubed and replaced (the cable is only about 2 years old, but got dunked with the boat). Problem progressed. Looks like signs of water entry. A couple of drops in there at most, pretty sure I would have noticed that when I last pulled the drive though. Anywho, I'm going to replace the cable with QS (last was sierra, which doesn't have a plastic coating on the cable), obviously replace the bellows. CV bellows were dry. I replaced the shift shaft seal with the newer style gen 2 in the past, but don't remember how long ago. Figure I'd replace that again as well (IIRC I don't need to press the housing out again?). Surfaces around the bellhousing gasket/gasket itself looked ok. Anything else anybody sees that I'm missing in the pic? Next summer is DEFINITELY the summer where I have everything working
