evanboothe
Thread starter- Joined
- Nov 20, 2023
- 12
Hello, I am a new member here and I just purchased my first boat.. I am a mechanic for a living, have done tons of rebuilds on other things so I am very (able) to tackle a boat I hope lol. It is going to take some learning, and Im already finding myself learning things the hard way.. I found this fourm and decided to join due to good info I have come across by browsing these threads. Okay enough with the intro...
Again 1998 Refal 1700 LSR, Has the 175 mercury jet engine.. Got the boat home and into my shop come to find the covers were leaking, floor was wet.. Imeditaly started cleanup and putting space heaters inside to dry it out as best I can. My main questions/concerns is obviously how long has it been wet.. and is anything rotted to the point where I need to take action before even attempting to take the boat on water. After further inspection and hitting things lightly with a hammer to listen for tone changes nothing sounds to off. I again might not be going about this properly as to why I am looking for advice. Lastly my 3 main concerns I can physcially see ( The star board around the window area on the right side on the boat has some spidering in the gel coat on the outside around the water line. I pulled back the carpet and do not see anything from the inside that looks cracked or damaged SHOULD I be concered about this?? Next concern is the storage area under the middle of the boat, the gel coat is cracked in the center. The wood is exposed BUT doesnt seem rotted, yes it was wet but does not seem soft.. What should I look into there or watch out for... LAST concern, Behind the engine, where the fuel tank is located, I can see some water between the tank the back side of the engine, there are no drain holes, not sure if it just got in there due to the cover leaking or if the section of the boat there is filled with sitting water.. no real way to access that area to inspect further. I will attach photos as soon as possible. Thank you in advance..
