rustybronco
Thread starter- Joined
- Oct 24, 2021
- 134
1995 Alpha 1 Gen 2
Can the lower unit drive shaft be removed without the tool (91-61067A3 pinion nut adapter) used to hold the pinion nut? I need to remove the shaft (45-816472) in order to properly? flush the lower and inspect the forward, reverse, pinion gears and shaft bearings.
Thanks in advance, Dale
