maineiac5586
- Joined
- Feb 14, 2009
- 828
New to me 1997 johnson 115 spl v4 bubbleback. Disconnected triangle connector under the connector panel after removing the cover of the connector panel (under the hood). Ignition key off I put a clamp on the green pin and one on the blue pin. Full down shows 158 Ohms. Meter goes to 1 while motor is moving up or down. I stopped moving the motor about 1/2 way and meter went from 1 to 158 Ohms again. Same ohm reading whether down all the way or trimmed up. Assuming the sender is bad unless someone says otherwise. Not sure which wire to use at the helm to connect to trim guage. Boat doesn't have a guage. Looking to add one . I see a triangle connector up at the helm but it has blue, green and red wires. Not seeing a brown white wire in that connector. I have a 2 wire connector that goes to the binnacle control. Need some help. Inputs welcome
