Captndrydock
Thread starter- Joined
- Mar 9, 2020
- 114
I've been on a roll getting motors to run, but ran into another puzzler on a Force 125. I can't get fuel to pump past the fuel pump. The bulb is tight and squirts out the inlet hose to the pump, but once fastened to the pump, I get nothing.
I loosened the other ends thinking maybe an air lock, but no luck. I've turned the motor over thinking maybe it needed the cylinder movement to pulse the pump. Changed the diaphragm, same. Swapped out for another fuel pump, no luck.
Not sure about the procedure to test the fuel pump, I guess that's next. But the valves moved when I pressed on them... So for the moment, I'm stumped.
As usual, always grateful for ideas or solutions!
