jnelsonusmc
- Joined
- Jan 18, 2023
- 41
Hello - I have been trying to fix this short for a while now. I need some help with a 2011 . The circuit that has a short is for fuse that is for Fuel Pump Relay, IAC and Ignition Coil. I disconnected the IAC turn the ignition switch on and fuse blows - disconnect the Relay and it does not blow. Changed the relay out and still blows the fuse when ignition switch is turned on. I traced it to the Red w/ Black Stripe wire in the fuse holder which is one of the wires for position A in the fuse holder. I found the Red w/Black Stripe wire on the relay as well but cannot find how the wire runs from the fuse bank to the relay. It says the fuse is for the IAC but there is no Red w/Black Stripe wire going to the IAC - there is no Red w/Black Stripe wire going to the ignition coil either. There are qty 3 - 882751 relays all in a line and I rotated them all and same result fuse blows when I turn the ignition on. It is hard to believe that all 3 of the relays are bad but I ordered 3 new ones anyway just in the off chance. If the fuse keeps blowing then there is a good chance that the Red w/Black stripe wire is shorted out somewhere in the harness correct? If I run an independent wire from the fuse holder to the relay, am I going to screw anything up? There is not a lot of wire to play with on either end so if I do this the chances of un-doing it are not good. Any help would be greatly appreciated. Fuse A in the picture below is the fuse that blows on me when I turn the ignition switch on.
2011 MerCruiser 3.0 MPI
Engine S/N 1A631142
Regards,
Jim Nelson
Engine S/N 1A631142
Regards,
Jim Nelson
