GhostriderL76
- Joined
- Dec 22, 2023
- 10
Alpha 1-Gen2 OM517265 (2002) (230 hrs)
Hello forum, 1st post here and could use some help. Pulled the lower to replace the impeller. Then pulled upper to inspect bellows and gimbal bearing. Bellows had about a 1/4 cup of gear oil. Ordered an upper seal kit.
Removed the nut and tension washer and disassembled the bearing pack and pinion gear from drive shaft. Replaced yoke seal and inspected and cleaned seal journal on yoke.
Cleaned pinion gear and pressed on bearings with brake cleaner and lightly re-oiled. There is no floating spacer as the shop manual shows, just two race housings that touch. Holding either race the other spins with very little to no interference with the other race, I can push the two bearings together by hand and get resistance on the race housings when rotating.
Do I need to get more clearance then this to begin the preload procedure? Do I need to press the larger bearing back a tad? I read where Chris just taps the pinion shaft while holding the race housing in hand to "clearance" a bit.
Thank you.
Thank you.
