The size and strong transom hint that is can be 15 HP or even 25 HP, but it would be good to know exactly.Probably 7-10
None of them were rated over 10The size and strong transom hint that is can be 15 HP or even 25 HP, but it would be good to know exactly.
You look at each one until you find the exact model (same length and beam at transom)Good list, but did not help me.
I only see some model numbers under SEARS==>1981 MODELS.
How do I figure it out?
There are numerous references on the web for 14' FB Sears Gamefisher boats rated for 25HP.None of them were rated over 10
Use the USCG formula.
Or look up the exact model from the specs posted
There is only one that fits my managements and it is rated for 25HP.You look at each one until you find the exact model (same length and beam at transom)
It is sold with 15 HP, not rated for 15HP.![]()
1981 Sears Game Fisher 14' Fiberglass Tri-hull Jon Boat | All For Boats
Description Condition: Used Year: 1981 Use: Fresh Water Make: Sears Game Fisher Engine Type: Single Inboard/Outboard Model: 14' Fiberglass Tri-hull Jon Boat Eng...www.all-for-boats.com
15hp
This ^^^None of them were rated over 10
Yes, based on hull# mine was also made by MFG.I had an '81 14ft a number of years ago just like that and the tag read
800lbs motor persons and gear, 25hp max
They were good boats, made by MFG.
Mine as getting fuzzy and giving me fiberglass splinters so I had to sand, primer and paint it back in the late 90's. I sold it about 12 years ago.
Here's a pic from the 76 catalog from online:
