biederboat
- Joined
- Feb 13, 2005
- 94
This outboard was running pretty good since I bought it used about two years ago but just now it's not running well. It starts okay (pretty quick and for a few seconds) but doesn't go down to a steady smooth idle (kind of on & off) and sometimes goes up to high throttle but mostly just stays at a rough/low RPM when trying to get it going at medium/high speed. This is even after a minute or so of keeping the choke on (it seems to stall quickly if you try to let it down after a short time). I cleaned out the carb, was still the same bad run, so I just bought a new carb but it still seems more the same of bad running. I can't say I'm a perfect mechanic but here's what I am pretty sure on:
1. It's very up/down on how it idles, sometimes sounds good, but then goes down and usually stalls. I more have to keep the choke on to keep it running.
2. Trying to get to a higher speed is also on/off. It basically stays at a rough and low RPM when you try.
3. The "low oil pressure" red light comes on but I'm pretty sure when it only gets down to a very low RPM, right before stalling. Oil level is good.
4. I checked the fuel filter and pump (ran it for a bit unconnected to the throttle) and it seemed to dispense fuel at a decent level.
5. The spark plugs are both pretty black (the same on both) but not thickly coated with debris, not sure what would cause this. I'm assuming that's an effect of whatever is not making it run well and that it's not the root cause of the problem.
6. I'm pretty sure my fuel tank and hose are good also, can't see anything bad with them.
Any ideas on what could be causing this? I am thinking of taking it to a mechanic but hoping there's something quick and easy.
Thanks!
Biederboat
Thanks!
Biederboat
