Mercarb 2BBL vacuum hose?
komodo_goods
Hello,
Thank you for all the help thus far in getting my boat correct.
I have the carb off to clean it, and this vacuum line was capped. Should it be, and if not, where should this be connected? It was capped on my 5.7
Mohawkmtrs
Normally connected to the fuel pump with a see-through hose (NOT the fuel line).
This hose allows the skipper to view the condition of the fuel pump diaphram. If you see fuel in the hose, you have a ruptured diaphram.
dubs283
Definitely not a fuel pump diaphragm rupture hose connection. It is a vacuum port most likely tied into a pcv valve in one of the rocker arm covers
For years and years mercruiser just vented the covers on gm based engines to the flame arrestor but in the late 90's/early 2000's decided to add a pcv valve and vacuum line to the carb base. WAG would be for emissions related/necessary for epa standards. Another component they added was an egr line from one exhaust manifold to the intake for epa compliance
komodo_goods
OK, thanks, fellas. It looks like I will keep it capped. FYSA, I already have the valve cover hoses running to the flame arrestor.
flashback
Be sure you route the hose from the fuel pump to the carb. Don't want raw fuel in the bilge if the pump fails.
komodo_goods
Currently there is only the feed hose from the pump to the carb. The overflow fitting has a set screw in the carb. Is there another hose fitting you are talking about?
Ayuh,... Do you have a mechanical, or electric fuel pump,..??
Scott06
I have a mechanical
Is this a pipe plug (circled) in your photo? that I believe is where I had one on my Mercarb. Mine had a 90 degree elbow threaded on one end and hose nipple on other. like this fitting in amazon link -
I assume this is off a different engine originally?
komodo_goods
Scott06: that is a set screw that is in place and not installed by me. this is a different engine from original. Based on the casting number of the block its a 1988-1994 SBC and the boat is a 1998. I'm also assuming that the carb is from the original 1998 5.7 which probably had an electric fuel pump and the reason for the setscrew in place of the diaphragm nipple.
komodo_goods
Ayuh,..... Then there should be a tygon tube from the pump's vent, to the top of the carb, or the flame arrester, to dump gas from a ruptured diaphragm, into the throat of the carb, not the vacuum port at the base,.....
ok gotcha. So what then is the lower nipple that is capped on my carb for? Would it have been used on a 1998 or newer 5.7 but not an older 5.7 (1988-1994) model which I now have in my boat?
flashback
The base of the carb has a standard vacuum port, it's normally not used in the marine world so it's capped. In an auto it could be used for spark advance. Or maybe the windshield wiper.
komodo_goods
ok gotcha on the lower nipple, staying capped.
