1976mercury115
Thread starter- Joined
- Sep 5, 2023
- 31
So I’ve had this boat for a while now and the motor has been giving me a lot of trouble it’s a 76 mercury 115. So far I’ve had to replace the spark plugs, coil, distributor, and clean all the carbs. So far it’s only ran like crap and I’ve taken it out 2 time to end up stranded each time because of the motor. The problem I’m having now is I cannot get it to start at all now one of the wires on my distributor corroded so I got a new used distributor to replace it. Before replacing it it would start and run alright but after I replaced it I started it and let it run for a bit then shut it off. Now the next time I went to start it it wouldn’t start at all just pop and act like it’s going to start but not actually start. I removed one of my fuel lines and put it in a jar to see that it’s not pumping much fuel. So I figured I just needed to rebuild my fuel pump well I got the rebuild kit and rebuild the pump, but now it’s pumping better but idk if it’s enough. When I crank it still doesn’t wanna start and when I run a fuel line to a bottle it’s will barely fill the bottom of a water bottle after thirty seconds of cranking. Is that about how much it should pump cause I know it only makes like 3 psi of pressure but I figured there would be more flow than just a little drizzle. Did I not do the rebuild right or is there something else that can cause it to barely pump fuel?
