Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Remove exhaust covers on side of engine.----Inspect pistons and rings.----How was this motor operated?-----What type of boat?----Oil injection in service?----Oil injection tested.----Oil injection pump still turning ?----Accurate compression test results should be posted.-----Overheat warning horn tested.----Impeller replaced every 5 years?
Thank you,I was sure I had a major problem until I noticed the top spark plug had no gap,it would appear that it was running on 3 cylinders causing rattle.
