leaking riveted starcraft ('82 MR180)
redneck joe
Not yet, wife out of the country for 10 days, free water to fill up the boat (rain) next few days, the spots on my lungs is not cancer so got a big jug of gin and relaxing with the dogs on the couch and in the garden next few days to celebrate.
Good luck on yours.
rxl650
Good luck on yours.
Thats plenty worth celebrating. One might say life altering. Enjoy the downtime and congrats on the good news.
redneck joe
Still have colon cancer, but caught very early so not worried. Surgery Tuesday morning. For some reason the lung scared me more than the poop chute.
redneck joe
Ok, so consistent drip out of the keel drain hole when I left boat conne Ted to truck, pretty much level. The water level was above the thru hulls and nothing there. Drained for a few minutes and lowered to the lowest possible on the tounge jack and stopped. So, rain next couple days and afterwards I'll crawl under and look more closely.
rxl650
My 15' tinner sat all winter level in the shop. Now that its propped up at the tongue, the keel and both strakes are dripping a little. The hull has absolutely zero leaks.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Sounds right. The strakes aren't watertight like the hull. They have weep holes to drain so water doesnt freeze and expand inside them.
redneck joe
Yes on the keel but the second round is dripped for hours.
Fill back up, now nothing like the first time.....
redneck joe
Swings haven't been that big that I wouldexpect that. Been leaking through overnights in40s to highs in 60s
redneck joe
I'm parking it for next month or so in the barn I guess next step will be the wrap and blower trick
rxl650
I know this sounds odd, but the seam sealer will expand the more it's exposed to water. I had an extreme example of this on a wee 12 footer at the weekend hideaway for many years. Every spring it would nearly sink in a foot of water then it sat at a dock all summer with no problems. Still leaked some under power, but some removeable floors kept everything high and dry. Free boat, beat it up for 12 more years. Dont even know who built it. lol
redneck joe
interesting. That has been the bane of my existence on all this is the inconsistencies, both on and off the water but bottom line is the amount going in is 1000% greater than what comes out. That one really messes my mind.
rxl650
Run an electricians tape/snake through the length of the hull. See what you come up with. Only thing that comes to mind is foam turned to sponge. Other than putting up with it, I'd say your headed for a project. Personally, I'm passed "full on" projects. I say that now, but.....
redneck joe
Thoughts on 5300 v sika 291? I want to use from the underside in the joints. I believe the silicone one the po had used is coming loose as I use the boat.
5200 is NOT UV stable. Sika 291 is. based on the failures I have personally had over the years, Sika or Lifecaulk.
redneck joe
Ok I'll ll run with sika. That was the windshield urethane we mostly used at the glass shops I used to run
still used in boat windows on center consols, at least at work they are.
tphoyt
I know a guy that wasn’t terribly concerned about speed and just peened all the rivets and then coated the bottom with truck bed liner.
He’s been leak free ever since and has no concerns with beaching the boat.
airshot
If silicone was used previously, nothing may stick to that surface....one of the downsides of using silicone besides the fact it doesn't last.
redneck joe
I planned on acetone then wire brush then acetone then fill? And this is just to hopefully stem the flow until I can replace floor and work internally.
