CaptStripSet
Thread starter- Joined
- Mar 22, 2024
- 3
This question is a 2 part question regarding fixing some damage sustained to my boat... I would appreciate any and all help very much! I hope to one day use that information and help others!
First Damage: I became aware by accident that my keel roller split in two and my boat got scraped and gouged from the keel roller assembly including the rivets and 2 gouges... I have tried asking some individuals who said this damage is mostly superficial as I have had the boat out many times without leaks after the damage...but I rather deal with it and fix it so I don't have issues in the future.. I am not sure what sanding/grinding/buffing wheel i should use? I bought "Goop Coat it" to seal the bottom of the hull as I used this boat regularly in western Montana rivers with rocky substrate and sharp objects.. I was wondering if I should jb weld and prime before doing so? The first 2 pictures are the damage and the keel roller assembly that did so
Second Damage: The second damage I found getting ready to clean the boat thoroughly in order to upkeep and get ready for the coat it on the bottom of the hull and it is quite dirty... the material that is cracking is foamy and i am not sure what it is exactly or what I should do to fix it and prevent leaking... Should I remove the foamy material and clean it then use epoxy, silicone, flex seal, rhino lining, gluvit, etc??? I am at a loss and love this boat so any and all information would be greatly appreciated! God bless folks!
