havoc_squad
- Joined
- Mar 5, 2011
- 739
Thank you!!!
NEXT QUESTION...
PAINT AND THEN WAX OR GELCOAT AND THEN WAX????????
PROS/CONS?
ADDITIONAL INFO????
Thinking on tipping the boat over after the new transom is installed and fixing the holes in the hull that I made, repairing any cracks or marks and then giving it a fresh new layer of gelcoat before putting it back on the trailer...and then flip it back over and start rebuilding.
THOUGHTS?
You either need:
1. some form of gelcoat on whatever exterior part of the boat that former had gelcoat on it
2. Or you have to use waterproof filler that will bond to the existing fiberglass & poly resin on your boat hull to smooth out the surface. Then when that is 100% you paint the boat hull with paint that is made to be used in a marine environment.
Paint in most forms simply isn't thick enough to fill voids left by fiberglass mat and cloth.
You can paint over gel coat (boat bottom paint is a prime example), the issue is surface prep and the right paint. The wrong paint will perform very badly on durability and will be a labor intense process to get rid of.
