Batteries are installed . . . It works (so far).
I spent most of the day cutting the 2/0 cables of the old system to length for the new power system and installing lugs. I usually crimp and then solder the lugs. 2/0 cable and lugs take a lot of solder . . . I had to go buy more.
Anyway . . . here is the panel with the battery and main power wiring feeds connected.
Still a few finishing touches needed. I did not like the covers for the bus bars, so I got to figure something else out.
Here is the battery layout . . . I wired everything up so I'l know where/how to install the battery boxes.
I had to configure the Xantrex Inverter to charge the LFP4 batteries. It does not have a specific LFP4 setting, so I had to use the custom setting and fudge it a little.
The only thing I did not see is the maximum charging voltage, which would be nice to set. The LFP4 batteries were charging @ 14.0 volts and 20 amps (10 amps each) and then started to go down after about 30 minutes or so. Perhaps they were not fully charged. I think 13.8 volts would be better, but the spec's do say 14.4 volts for charging. I assume with 3-stage it will go into float mode at some point.
The inverter is still magic to me, but I'm getting more familiar with it. Here are some more screen shots . . . comments, pointers welcome.
I reset the ProNautic to charge the LA batteries (engine batteries). I noticed the flooded/sealed battery charging voltage is 14.8 volts, which seems pretty high. I'm wondering if the world would end if I used a different setting that has a lower charge voltage.
Here are all the batteries I surplussed from the boat . . . all 500 lbs of them.
I've sold 4 of them already.
