guitarplaya39
Thread starter- Joined
- Apr 14, 2019
- 34
So could this be caused by a lean condition in that cylinder? Perhaps it's only fouling closest to the intake?Fuel pump diaphragm should be checked.
I've always just used stock components. It's been fine for years so I'd rather just stick to what Mercury recommends.Why are you using those....Surface Firing sparkplugs ? They are way too easy to foul-up. Change to a Standard Style of sparkplug. I had the same problem with both old Evinrude engines. Check that the 3 carburetor linkages are closing the same amount both positions.
Definitely fully seated on both ends, but I'll try swapping wires or testing the resistance.Check that the sparkplug wire is FULLY inserted at both ends. Possible poor connection or failed wire.
Can you swap that bad cylinder H V wire with another cylinder wire to see if the wire is bad ?
I totally agree on surface gaps. The Mercury service manual for my engines lists surface gaps and a conventional gapped plug alternate. On the location of the carbon buildup it depends on the fuels position within the combustion chamber when the plug fires. Fuel enters in a swirling motion.Why are you using those....Surface Firing sparkplugs ? They are way too easy to foul-up. Change to a Standard Style of sparkplug. I had the same problem with both old Evinrude engines. Check that the 3 carburetor linkages are closing the same amount both positions.
