Water in fuel
Jhayes780
Hey guys there’s a ton of water in my fuel tank. What’s the easiest way to clean it. Was thinking add another water fuel separator in line letting the water settle to the bottom of the tank then pumping it out till I get better looking gas adding the separator and calling it good? Any issues with that? Sorry in advance if this is a dumb question
Letting the water settle to the bottom of the tank is a good idea. Now siphon from the bottom of the tank, into a clear container. One of those "shake-shake" siphons work's well. You should let the clear container settle and you should be able to see the different layers. If in doubt, a splash of 2 cycle oil will color the gasoline and alcohol, but not the water.
After you get out most of the water, as much as you can, a single water separator can be used. Remove after running a while and dump into a clear container and see how much water remains. Repeat the empty of the water separator on a regular basis until the water is gone or nearly so.
^^^ Agree
Will add once water is out the gas will probably no good to use.
airshot
FYI....I picked up a small 12v inline fuel pump off Amazon for 12 bucks, added an inline filter and a couple lengths of fuel line , does a great job of pumping out fuel tanks. Filled a 5 gallon can in about 10 minutes...sure beats siphoning. !!
Gee, my shake-shake siphon will siphon 6 gal of fuel in 5 minutes or less. It has quite a large diameter capacity and doesn't require electricity and lasts for decades.
How old is the gasoline? If it is not too old, it should be fine to use after the alcohol/water mix is out of the tank.
Sprig
I think before you do anything you need to determine the source of the water.
flashback
I have done this, I had a piece of copper soft pipe so I could access the lowest end of the tank.thats where the water settles..
airshot
Good idea, I had some old solder, so wrapped a few wraps around the end of the line and it seems to keep it low in the tank. When I get all I can out, add another gallon and slosh it around then suck that out. So far so good...
Jhayes780
Thanks everyone for the help. I just siphoned it. Installed a water fuel separator. And put in some of the stable that is supposed to help with wanter. Am I good to run it anyone think?
04fxdwgi25
How old is the fuel? Is it ethenol free or regular pump gas. Us not knowing what you have is hard to call. But, If you don't know condition of the fuel, then the safe money is on getting it out and putting in new.
Stabil is to keep old gas sort of new while setting over the winter, it won't make bad gas good
Try it, if motor runs ok then your good, if it doesn't then it all has to come out and need to empty filter and carb again
