stormyj
Thread starter- Joined
- Aug 1, 2017
- 48
Hi all,
I changed oil in my bravo 3 lower unit and found some water in it. Removed the drive and its sitting on my bench right now. Was going to put together a pressure test set to see where it is leaking. Heres where Im curious. where are the points that it can leak under water. Yes, I know, anywhere, i just want to know what seals and where they are located. Im sure the outer prop seal can leak, but where else can it leak and where should I just replace the seals to be sure I dont have a problem. After I replace any seals I will do a pressure check on it to ensure it is not leaking. Thanks for any help.
