Seasons Recreational
Thread starter- Joined
- Jul 18, 2023
- 49
Hi all!
I am having my 14’ Sea King repainted as we speak and am starting to think about the electrical. I have a 2004 Johnson 9.9hp outboard that draws about 7 amps. I would like to do a 2-battery setup (house and Crank) and am having trouble figuring out the wiring. I would like to use the Blue Sea Systems ‘Mini Add-A-Battery’ system and a Blue Sea Systems 12 fuse block, split into 6-24 hour and 6-switched. I would also like to have a 6-switch panel. I am planning to add a trolling motor, but not sure where it would connect to the system. I’ve attached a wiring diagram that I’ve been able to scab together based on what I’ve learned. I have terminal fuses, but don’t know if they’re required. I have 60 amp breakers on each positive terminal. Hoping you all might be able to pick apart my diagram to see if it makes sense or to let me know where to tweak! Thank you all! Also, not sure what gauge wire. Figuring 8ga from battery all the way to fuse block, then 14 everywhere else. Thanks again!
