That old Mercury
Thread starter- Joined
- Oct 12, 2023
- 150
Hi
I have bought a boat and the bottom carb was flooding through the vent tubes. Carbs had been worked on prior to purchase.
Rebuilt both carbs and bottom carb leaking with air pressure test.
Swapped bowls and tested again and it had a small air leakdown
Lapped needle seat and that stopped the leak.
Put carbs back on pumped bulb and gas was leaking out the vent again only after a few days sitting.
Checked plastic bowls on both and they were warped.
Sanded both bowls and no leaks for 2 months on top carb , now back to leaking , flipped gasket over and done a leak down test No leaks.
What i see it gaskets starts leaking between the carb and float bowl so it fills the carb full of gas and it over flows the carb.
Does anyone know of a metal bowl replacement for this carb?
335830-CS or it may be 09
Float chamber #398 544
