Monterey276
Thread starter- Joined
- Aug 11, 2023
- 36
Looking for some advice on patching this correctly.
I discovered a crack in the gelcoat where my bilge pumps/switches mount. I initially was just going to grind out the crack and put some marine tex in there to fill it. After I opened it up though, I discovered a lot of water underneath there, it was squirting up when I’d push down next to it. The boat was built with a piece of wood, I think it’s probably 1x4, in this spot. I assume it’s designed that way specifically for the pumps and switches. Anyway, I cut out an area in the center and have had a fan blowing directly on it for a few days. I’ve grinded down the surrounding area just enough to get the gelcoat off.
Did I prep this correctly? I have CSM, some woven fabric, and polyester resin to make the patch. Not sure how many layers yet but I plan to just make it the same thickness as before.
Any suggestions or tips appreciated
