Which Ignition Switch for Merc 5.0
Lancerdad34
I am looking to replace the original ignition switch in my 2007 Sportcraft with a 5.0 mercruiser. The original is sealed and has no posts to attach wires to. Before I start cutting wires to connect a new one I want to make sure I get the right one.
Thanks,
Brian in MI
Bt Doctur
If you have an accessory position then you need a 4 wire type
Red 12v B
yellow/red S solenoid
purple I ignition
accessory pink? A post
Lancerdad34
Red 12v B
purple I ignition
Thanks for the reply! No accessary position.
Newer Mercruiser and Mercury switches are as shown with the connector to allow the halon interlock harness to be simply plugged in.
