mrzooom
Thread starter- Joined
- Mar 31, 2023
- 80
Ok, this old mid 80's 120 came to me non running. Installed starter, got crank. No fuel to carb from pump so I I installed brand new carter mech fuel pump had laying around. Fuel restored to old crusty 2bl carb. Disassembled carb, cleaned it, reassembled and installed on manifold.
Charged battery, 12v to + coil. Strong spark at plugs. No fire? Purple wire at coil +.
Kind of brown and tan (2 other wires) at coil+. Dizzy black to coil-. Tan tach wire at coil-. Boom, no fire??? Ok, took all connections off dizzy except dizzy wire. Jumped from battery to coil+... Not only did it fire but almost knock me out of boat... Anyway without throttle linkage I had no way to much. It reved up like a rocket while just grabbed high tension lead off coil and disconnected the battery -..
In addition to some forien metal sound bouncing around, it was spitting out milk shake into bilge, etc.
What happened? Any suggestions? I have no idea...
Scott
Scott
