Transom grounding wite
ltfella
Hello I have 1989 Mercedes 5.7 when looking at the transom the top right plate has about4 inch ground wire all metal.id like to know where the other end screws into into for the grounding. I can’t Seem to find any screw holes
matt167
Top goes to the steering arm. Bottom right connects to the engine. There’s a stud on the coupler housing
ltfella
Ok I knew the bottom but couldn’t find the top will look when I get home thank you
matt167
the screw hole is in the top of the steering arm. If you are missing the screw it’s probably a 6-32. You will want stainless
