No feedback helm question
maineiac5586
Just wondering if it's OK for there to be about 2 inches of back and forth when you push on the outboard as if trying to steer left or right? I know the design of the helm won't allow you to manually steer the motor when pushing on the motor one way or other but I have little play back and forth. Only asking because I just moved my outboard up 2 holes and noticed this when back there doing the change. I can't remember if it was like that after I installed the helm a couple months ago. I'm a worry wart sorry. I have used the boat since noticing this without an issue
That sounds like a lot of play. I presume you are discussing a cable NFB system. See where the play originates. It could be the motor mounts or some parts of the steering system.
maineiac5586
You can see the movement where the cable goes into the tube. New cable 2 months ago
So the cable has the play? Some R&P systems had an adjustment screw Other than that, I am not sure.
