Engine cant idle
nennedk
What's going on here? There's no problem in starting the engine (after a couples of priming), but it keeps dying soon after as heard in video 1.
I can keep the engine running if I keep it above 1500 rpm.
Video 2 shows how revs is going up and down by it self, before it dies (when the engine is warmed up a bit)
Mercruiser 5.0L (2 BBL.) GM 305 V-8 from year 2001
  • video1.mov
  • video2.mov
You have a leak at the carb base. You can see it in the video
nennedk
It looks like the hose is off the valve cover PCV valve.
Well spottet. I think you are right and i had actually the hose off resently. I will look into it next time i’m at the boat, hopefully tomorrow
nennedk
Ha ha, it was the hose. I believe I must forgot to put it back on after I have detached it. Now the engine runs smooth again. Thanks
