- Joined
- May 16, 2009
- 9,452
Lol,...There was a time when this was easy for me to help figure out...All Ted and AD are doing lately is making sure I myself don't buy anything "new" too.Teds Luddite build coming next.....
OK - I'll get my contortionist outfit on and take a look I believe it is all stock set-up, but I'll check.No problem, next time you're in there try to take a peek.
I'm thinking if the wire is orange then it's a stock set up and running down by/to the engine starter...If red then usually something aftermarket with an isolator of some sorts mounted elsewhere....Try to follow the wire just so you know what's going on and if it could be a potential issue on top of anything else.
I feel more suppressed than the relays . . . or would that be depressed, not suppressed.Ted, are the relays diode suppressed?
This is pretty much what I was thinking. Probably easier to pull fuses than pull wires. Didn't think of a diode (mine only has one buried in the alt I think); I wonder if there's one separating the different batteries somewhere. This really seems like a "too much power where it shouldn't be" problem rather than a "not enough power to where it should be" issue.One thought that comes to mind to consider trying as well would be while the relay is buzzing, start pulling one fuse at a time all over the engine to see if maybe one of them is back feeding but pull the Main relay fuse last if possible.
Also is this happening when the boat's other house power is powered up too?
Maybe it's a bad diode someplace.
I did some current draw testing on the port and starboard batteries, but did not see anything of significance.Could that be a sign of a parasitic draw?
I had to track one down on my old 98 Jeep. Turned out to be a rusty relay in the trailer tow harness..
Trouble is you need a crew to sail it ---and-----Ted.... over 505 years old.View attachment 399022... operates same as day it was built. (no electrics)
Hey, I've got that same timing light. Customer bought it and gave it to me after he "moved" my much more expensive one so it got into the spinning belts. I felt that I was partially to blame, so I never said anything to him. But I did start enforcing a new rule ---- customers are allowed to watch but must stay at least 6' away at all times.
