cyclops222
- Joined
- Mar 21, 2024
- 3,142
I feel for you. You have so many different things to correct. Stay with it.
Haha I do I really do honestly wanna give up but I really wanna go fishing in the boat I’ve never been fishing out in a boatI feel for you. You have so many different things to correct. Stay with it.![]()
CDI electronics has a trouble shooting guide to check the ignition-system.So adjust my floats. And then figure out why I can’t adjust timing. Would it be a bad cdi box or coil
I live by these stepsAlso known as the "Ten Steps to Success".......
Same here.....if you want success, follow the steps....lol.I live by these steps
Ok thanks I wasn’t sure on that. I just ordered one. Did I have the setting right or should I change itYou have to use a DVA adapter to measure voltage right when troubleshoot CDI ignition systems.
A DVA adapter is a single wave rectifier with an electrolytic capacitor and you use it because your are not able to read the peak voltage with a VOM.
The DVA adapter rectify the AC voltage in to DC voltage and store it in the capacitor. Then you are able to read the peak voltage because it take some time for the electrolytic capacitor to discharge the voltage.
You can measure without a DVA adapter but you only see if the stator in this case put out voltage, but you do not see how much voltage.
The Prestolite system used on these Force engine need a stator output voltage DVA from 210V or higher to work properly.
With the DVA adapter attached, set your meter to DC (high) voltsOk thanks I wasn’t sure on that. I just ordered one. Did I have the setting right or should I change it
Even if there were 12Same here.....if you want success, follow the steps....lol.
Good one!Even if there were 12![]()
I got the multimeter set to 600 my highest dc volt setting and it was putting out 164 between 1-2 and 154 volts between 3-4 for the stator. It says to set the multimeter to dva 400 but I only have 200 and 600 is 600 ok?With the DVA adapter attached, set your meter to DC (high) volts
Ok I’m glad at least I know the problem now. Hopefully that’s allYes it is.
The range of the multimeter tells you how high values it will manage at the range you have choose.
If you got 164 and 154VDC with the DVA adapter the stator suppose to be bad.
You should have 210VDC or higher at cranking speed.
The covers are more a sound deflector & when tilting the engine; it's normal that gas leaks out of the throat of the carbsAlso I took the carbs out gave them a very very thorough cleaning and the floats were adjusted properly according to the manual. Some I’m not sure why the carbs are leaking. Also the carb covers have a pocket to catch gas. Does that mean it’s ok for some gas to come out
"The tdc mark stays relatively close to the main timing marker"Update. I got a new cdi stator installed it put all the leads correctly. When to time it and it still would not move. The tdc mark stays relatively close to the main timing marker.
It also doesn’t even putter now before I could get it to start for a second or 2 now it doesn’t even want to start.
So I went to measure the voltage between the leads and for 1-2 I got 174v for 3-4 I got 164v which is 10v more for both sides but still not 210. Do I have to remove spark plugs?
So my main question is why can’t I adjust the timing. Did I **** up the fly wheel by drilling and taping new threads for the pull in new locations. I woodruf key is there and perfect condition.
And did I get sold a 350$ broke. Stator
Does the Orientation matter for the stator
I just wanna go fishing on a boat![]()
