- Joined
- Jul 7, 2010
- 15,126
You may want to do a couple of checks on the Stringer drive: 1) pull the upper gear case and see if it turns free. You should be able to turn it by hand (or maybe using a hand tool), but it should move relatively easy. Then you may want 2) test the lower to see if it shifts into gear.
If either of those two things aren't happening properly, it's a gear box rebuild. Kenny, Scott or Lou know more about that than I do. If you're confident rebuilding transmissions, you may be all set. I was less than worthy
