jitterbug127
- Joined
- Feb 6, 2023
- 629
I have a 1976 Johnson 25 HP outboard. It continues to sputter out and die even after testing and replacing parts. I converted it over the the universal magneto from the low tension magneto because I have all the extra parts (and I like universal magneto better). Motor has brand new points (i filed before installing) and condensers. I thought the front coil was bad due to it appearing to have intermittent spark. I replaced the front coil with a couple different coils from my spare parts box. Still having same issue where it will run for 10-30 seconds and die.
My next thought was fuel pump. I replaced the fuel pump with a different one i was 100% sure worked. No resolve. I took carb apart and it looks spotless and has a OEM rebuild kit in it. Friend of mine actually cleaned carb a few months ago. I think its good to go.
Compression is 115/115. Spark will jump a 5/16" Gap with ease. This motor will start basically every single time I pull the rope. It wants to die after 30 seconds or so.
