shellone
- Joined
- Jul 18, 2009
- 48
On a Searay 250 EC I have a Merc 7.4 with a Bravo drive; double propeller. No secondary gear lube container. The boat is on land since last August, everything was fine two months ago during last test. Today, 15 seconds after turning the key to 'on' a buzzer started (I say 'a' because I do not know if there is more of them). It did not go off. I double-checked the basics and since everything was ok I started the engine. Came just fine, cooling worked, just tried briefly switching in forward, worked perfectly. Oil pressure was good, water temp did not show any reading but risers were cooler than before engine start. Obviously there was enough oil and oil pressure, not overheating ... so what might cause the buzzer ? Turned off the engine, switched back to 'on', and in came right away. Disconnected the batteries, of course the buzzer went off, batteries back on, buzzer back on simultaneously. Does that drive have a sensor for drive lube level inside ? Would that be the first thing to check or in there something electrical that I might wanna tackle first ? Thanks for any idea or suggestion !
