saltchuckmatt
- Joined
- Jul 19, 2019
- 3,367
Buy a used carb....Tims outboard service. Don't give up on this motor, new ones are not the answer.
timsoutboard.com
timsoutboard.com
So I just got off the phone with the mechanic. He is telling me to not even bother putting any more money into this motor. He started to explain that the motor is probably shot, saying that the bottom skirts of the pistons are probably worn to where the block is getting no vacuum, he also explained further that I would still get fair compression readings with this problem given that the top end of the piston is still ok. He also stated it is one of the most common problems with this motor after its worn down over the years.You will be delighted with a new 4 stroke.-----Computor does all the thinking for you.------Trouble free boating with a 4 stroke until there is trouble.
Message received, I have seen you say this before in multiple posts. I will probably go that route next given I am out of options at this point (what is there to lose). If I do so I will be sure to take some pictures and video and post them up here. Thank you so much for your time, your a huge help to everyone here and I'm sure you don't hear that enough.See post #18-----Taking the cylinder head off to inspect cylinders is the quickest / easiest / most cost effective step in trouble shooting.----Very few people can accept this simple fact.
Very doable yourself, but you need a factory service manual for the steps and follow them to the letter !Alright time for an update, I haven't given up on the motor guys don't worry. I was just venting out of frustration before. I went ahead and did a full rebuild on the Carbs. I am now leaps and bounds closer than before.
It is idling again now, the Idle is a little rough it doesn't seem too happy.
Alot of progress on running throttle open, so it will now let me run wide open at first, it doesn't cut out dead anymore but after about 1 second i get a loss of power, it doesn't stall out if I had to guess i would say it bogs down to about half throttle worth of power? I drop the throttle and open back up and same thing she will open up for a second then bog back down. But it doesn't stall at all through the whole process, it will stay running.
I also went ahead and ran another compression test since she was warm and I figured why not. I got 140psi on both cylinders.
OVERVIEW:
REBUILT CARBURATORS
INSTALLED NEW FUEL PUMP AND LINES
NEW SPARK PLUGS (CHAMPION)
GAPPED SPARK PLUGS, 30 OVER
FLUSHED OUT OLD FUEL IN TANK, REPLACED WITH NEW FUEL AND SEA FOAM.
the last factor I haven't covered and I feel it's going to end up here is link and sync. I don't know how to do this, is this something I can achieve? Or am I going to have to rely on someone with more expertise?
I still have the original user manual for this motor I take it that will have my information?Very doable yourself, but you need a factory service manual for the steps and follow them to the letter !
User manual means nothing. The factory service manual is what a service tech uses uses to service the motor. It will have all the adjustment and setup specs you will need.I still have the original user manual for this motor I take it that will have my information?
It wasn't running then either. I wish that was the answer.Red lever must be inline with valve body to run.
as mentioned make sure the tiny idle pickup tube is 100% clear and alcohol or carb cleaner sprays out the tiny little idle calibration holes on the rearward "roof" of the carb just behind the throttle butterfly's. will need to hold them open to check while spraying. once together, manually blow into the carb with it upside down. should NOT be able to blow into it. now gently tip it right side up. is it clear/easy to blow into? this eliminates any needle sealing issues.Ok thank you so much for the feedback, I am going to mess with them some more today. I will make sure to get pictures and post them here so maybe you guys can see something I cant.
