havoc_squad
- Joined
- Mar 5, 2011
- 741
Anybody know if the interupt circuit on Delco EST distributor is vulnerable to damage if it is shorted to ground if it was not first replaced with 12 volts?
If so, that could explain the distributor module's weird behavior and that would not be covered under warranty because of improper installation.
Many electronic components come with that warning, warranty void if improperly installed.
The Delco EST kit instructions from Michigan Motorz also says the following warning as well:
"If the timing shunt is connected to 12+ volts while attempting to start the engine, the ICM (Ignition Control Module) in the distributor may be damaged and is not covered under warranty. If the engine needs to be restarted while the timing shunt is installed and connected, DISCONNECT the timing shunt before restarting to avoid ICM damage"
See if marine technicians have good success consistently with it but DIYr's have constant problems.
If so, this is a big red flag that people are not reading the instructions carefully and toasting the electronics in them.
They just want me to keep trying modules but I'm not interested in that after seeing others having the same issues all over other forums.
