twerth
Thread starter- Joined
- Aug 28, 2018
- 21
I'm pretty sure I removed the PV and cleaned the passages, but one more time can't hurt. Just for grins, I've ordered a new float (they're relatively cheap). When that gets here I'll check the power valve while I'm installing it.The power valve itself unscrews from the floor of the bowl you may need to cut a slit in a bigger flat blade. If you took it out and cleaned behind it just make sure the pin that sticks up moves freely.
the actuator in the bowl top is peened in there. No need to remove just make sure it moves freely.
Not sure what ignition set up you have. My 91 had the distributor less igniton which has separate coil packs on starboard back side of engine, and what looks like a sawed off distributor base as the trigger. The more common and more durable Delco Est is likely what you have. YEs on this you need to put in in base mode to set timing which is not hard. If you have a light check to see where timing is without putting it in base mode should be around 12-15 degrees at idle and go up to about 24-26 total at 2800 rpm or so.
Also get a spark gap tester to see how much gap it can jump . this is a quick test for spark strength. should jump 3/8 or more and be a nice blue spark. If weak or orange maybe issue with ignition system. Take a look at spark gap test when it is running good and then when it is missing see if there is a diff
My ignition is the typical electronic type with single coil and distributor. I've checked spark with a gap tester both in my driveway on the hose and on the lake when it was acting up. I only had ~1/8" gap, but I got similar results both ways. That doesn't appear to be the culprit.
Any thoughts on the potential manifold leak? That's still my prime suspect.
Thanks again!
