JohnnyGuy
- Joined
- Aug 24, 2017
- 193
I'll double check the idle calibration holes.are you sure the tiny idle calibration holes in roof of carb are 100% clean as a church ****-house? what about the tiny tiny idle pickup tube. a syringe with alcohol is all thats needed on these if its not a total nightmare. not much synch n link accept as you said get cam roller to just start opening at hash mark. no timing really to adjust, although this might be the year OMC experimented with a timing pointer but still kinda not needed. compression is fine? hot 7/16'' spark? a power pack can break down under load but spark at the plugs, which is why they want you to use a load adapter to cranking volt test it
The is a pointer that's mounted on the starter, but with it being cdi, is there really much that can be adjusted?
You've got me thinking maybe it's the powerpack though. I swapped powerpacks with an extra from a parts motor I had and it made no difference so I just assumed it was something else but in all honesty I have no history on that powerpack so maybe they're both duds.
