Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
Thread starter- Joined
- Oct 15, 2019
- 656
According to that calculator, the engine is turning around 4750 RPMs. Either that, or the final drive ratio is 1.28:1 LOLView attachment 390670
Boat Propeller Calculator - Good Calculators
You can use this boat propeller calculator to determine one of five variables: boat speed, propeller slip, propeller pitch, engine gear ratio, or engine revsgoodcalculators.com
Earlier in the build I turned the input shaft and counted the revolutions of the output shaft and estimated 1.88:1 That was based on a 17 spline output shaft rotating one full revolution, plus 15 of the 17 splines. Therefore, I think that 1.85:1 is likely correct.
I'm going to verify my tach before I go any further.
