wild.coast
Thread starter- Joined
- Sep 17, 2022
- 20
18ft alu RIB with 50hp Yamaha. Current have the fuel tank and battery jammed right in the back by the transom. Looking to clean up my wiring and add a proper fuse box and stuff, so wanted to move the battery somewhere else with more room - curious if anyone has any advice!
I've heard that shifting weight forward helps a lot with handling and weight distribution. The boat has two bench compartments: one is the bench the driver sits on and another bench near the bow, pics:
Apparently I don't take photos of my boat so you get some sea cliff climbing action!
The obvious/convenient place is the rear 'driver seat' bench, putting the battery beside where the driver would be sitting. I'm just thinking maybe it doesn't shift weight forward much. The front bench is a bit more awkward, smaller entrance and would mean I would have to make super long battery wires to reach the outboard, not sure if that's a problem. The other option is to put the fuel tank at the very front, but again, would need super long fuel lines, not sure if any issues/problems with that? In short, easiest and most convenient is the rear bench but if it's worth doing all the extra work to shift it all to the front then I want to know!
Thx so much!
Thx so much!
