Ford 302 mechanical fuel pump
Jakem
Good day, looking for suggestions on fuel pump part number. I ordered one of Amazon that said it would work however the arm looks slightly different
Jakem
This is what I ordered
Jakem
Right how ever the arm is different then the pump I pulled out..slight difference
Jakem
Sorry this is the pic I meant to add.
Lou C
Yep, the OEM Carter is what I put on my V6. Original lasted 30 years!
Jakem
I have a feeling it is yes...it wouldn't start last time out so my partner cranked key while I watched fuel filter and it wasn't flowing...let it sit..did it again and it filled filter speratic it seemed. We idled back to dock...if I gave it any throttle it died
Scott06
Ok hopefully this is it... I forget did you land on a holley carb or are you still using the rochester?
Jakem
I had the engine running great last year and had to pull it to rebuild floor and transom. Just working the bugs out I think
