ingham01952
Thread starter- Joined
- Jun 28, 2023
- 81
I have a 2004 four wins Vista 288 with dual Volvo penta 5.0. Picture attached. I have dual 60 gallon fuel tanks that are controlled by shut off valves in the event you want to direct one tank to both engines, etc.. I have questioned whether or not these gauges are accurate or in sync. I learned the hard way that empty on port tank, is in fact emtpy. The reason I put myself in that position is that I had same amount of fuel in both tanks and noticed the port fuel tank depleting much faster than the starboard. Yesterday I put in over 50 gallons each tank. I noticed the port tank once again significantly lower after a couple hours of use. I put in another 20 gallons and after about an hour of use I noticed it again lower than the starboard tank. My thought is that though the valves are wide-open, they are possibly misscalibrated? Picture attached.
