Another gear oil thread... 80w-90 vs. 90
Homerr
So what's the deal... seems the straight 90W high-performance drive oil is hard to find at local stores? Their shelves seem to be packed with 80W-90. Yes, I know there's little difference between them.
Is 80W-90 the new normal for other folks too? I've always used the Quicksilver (yellow label) High Performance 90W. I can always get it from Amazon or other online sources. Sucks that local stores don't carry it anymore, or at least mine doesn't.
Scott06
Never been in a Walmart that didn’t stock high perf gear lube.
what are u putting it in?
Homerr
2001 Alpha One Gen II drive.
I avoid Walmart like the plague. Now more than ever since they've locked stuff up worse than Alcatraz! I will not step foot in that store unless it's an absolute must.
Maybe it's just my local stores that just aren't carrying the straight 90W anymore and carry the 80W-90 instead. I was curious if other people are seeing the same thing in their towns.
stevedan
only use Yamaha lube products on my 2009 150 HP 4 stroke motor, not sure if that is the best product, but the OEM sure like it,, LOL,,
Scott06
Yeah not my favorite place but I do get motor oil etc there. There are other places like the local marina but certainly not a ton of spots. I do think the local advanced auto or auto zone may have them too
You will likely be fine running 80W-90. I do think amongst marine gear lubes a straight 90w is a bid of an oddity, though.
Lou C
Living on an “island” we have plenty of boat supply stores so don’t ever have to go to Walmart lol.
tank1949
I believe marine gear lube has some additives not found in std automotive gear lube. Maybe not... I'd stay with marine and what manual recommends.
Scott06
they do have additives that are supposed to make it still lubricate in the presence of water. You can use automotive gear lube which also works fine except when it got water in it. I used to use Mobil 1 75w90 in my sea do jet pump instead of the OEM lube. If definitely was less tolerant to water intrusion than the marine lubes I have used like the Sea Doo XPS synthetic, Klotz, or the Merc Hi Perf lube.
The sea doo xps at $20 per 6 oz is insane, but the klotz for $7.50 / 6 oz and Merc Hi perf at $15 qt are fine
jimmbo
Being that Marine Engines have such small Gears, the Marine Gear Oils may contain more EP additives to reduce the Wear on the smaller Contact Areas of those Gears.
Lou C
I have used Merc/Quicksilver High Performance gear oil in my Cobra on my previous mechanic’s recommendation and it has kept it shifting like new for 20 years, all salt water use.
Proper marine gear oil is cheap compared to gears / bearings and shafts.----If no water gets in it is good for 3 seasons for most folks.
cyclops222
I could not find a S A E rating different than 90W or 80 90W
Gear oils are ALL supposed to only be in SEALED gear boxes.
All other great sales words are just that.
jimmbo
A lot of Marine Gear Lubes are 75
No, Every Diff I have ever had was Vented, thus not Sealed.
Ask anyone who ever submerged the Diff and Vent Hose at the Boat Launch, they usually were replacing Bearings within a few Weeks
tank1949
My Bravos have lube reservoirs that gravity feed gear oil to OD. I don't think reservoir is sealed other than a cap, which has a hole in it so it can breath.
DarrinT
I have used Motomaster 80w90 automotive high pressure gear oil in my 1973 starcraft merc 140 since 2007 zero issues and I change it every year
Canadian tire has 5 litre jug $49.99 cdn ( 1.32 gal for $36 us thats $4.69/oz ! )
buying it any other way is a complete ripoff
???----Are you sure on the $4.69 / oz -----Seems 1 US gallon would be 132 X $4.69 I think.-----An imperial gallon would be 160 X $4.69
DarrinT
us gallon is 3.78 litres
imperial gallon is 4.54 litres
my calculation is correct
dubs283
This calculation is incorrect
1.32 x 128 = 168.96 fl Oz
$36 ÷ 168.96 = $0.213 per fl Oz
Your math equates to:
$4.69 x 168.69 = $792.42 for 5 litres (1.32 us gal)
School was a long time ago.----Forgot that a US gallon is 128 ounces and not 132 ounces.
Simoniz
Ive only ever found it once in Walmart Long Beach (just behind the airport), maybe I need to check out a different store.
